					Originally Posted by Flavor 987S
				 MORE TIPS:
 -Tires should be overfilled to 58 PSI (this is in your manual). I use Nitrogen.
 -Park on a sheet of plastic- painters tarp from Home Depot.
 -Desiccators in the cabin- keeps air fresh and protects leather and wood.
 -Block wheels, don't use e-brake.
 -Manually turn engine over in the spring by pushing in 5th gear. You will hear the engine turn over and take big gulps of air.
 -I move the car the beginning of every month, by hand, about 10 inches. Further prevents flatspotting.
 -First drive of the spring is about 350 miles, and then buy fresh gas.
Wow,  I take the tires up to 50 and throw in fuel stabile... and drop the insurance to storage level.  And this year I get to put on a used car cover.  Maybe I'm not doing enough?  I do use a 78% Nitrogen mix for the tires.
