Old 11-04-2009, 06:05 PM   #1
Jaak
Jaak's Avatar
Originally Posted by husker boxster
What's the logic in changing the oil before you store it? I would think you'd want to do it after you pull it out of hybernation. Wouldn't there be a chance moisture could form on the inside of the block while sitting for a long period of time? If you change oil before putting it away, that moisture would get in your new oil. If you change it when pulling it out of hybernation, the new oil would be free of moisture.
What am I missing?
Contaminates an such in the existing oil will cause problems as it sits over the winter. CLEAN oil is what you want sitting in it ...
2002 Boxster S Seal Grey
2010 Ford F150 FX4 Luxury
Retired after 38 years with the same company.
Jaak is offline   Reply With Quote
