Originally Posted by ElStevano
The fog light bulb is out in the passenger side tail light of my '99 Boxster. It's a p21 bulb. I pulled out the light assembly and replaced the bulb and it still doesn't work. It's the only bulb that isn't working. I checks the A7 fuse for fog lights and it's fine. The other fog light bulbs work fine. I double checked-tested the bulb on the other tail light and the bulb is good. Driver side rear fog bulb works.
One of the first hacks I performed on my '98 was to add the passenger side rear fog lamp.
Because it isn't wired I had to connect it in parallel with the driver's side lamp.
Now I can turn it on at will.
Very handy when someone is tailgating. It looks to them that you stepped on your brakes. They are much brighter than the brakes.
Happy Boxstering,
Pedro
