Old 11-04-2009, 05:41 AM   #6
ppbon
ppbon's Avatar
Originally Posted by eurotic spaniard
[B]1) Replace my Convertible top w/Glass Window. It has a hole thru the plastic window. I'd like to know what cloth type you would recommend including whats better for sound proofing outside wind noise. (fyi...During day here in my part of So Cal its usually hot to mild with a few months of rain. Nightime temp rarely get below 60 degrees)
My recommendation for the soft top would be to stay with Porsche.
Try to find a complete soft top assembly for an '03 or '04 (which have the glass) from a dismantler.
there are many advantages to doing it this way:
a) You can do it yourself and save a ton of money, because installation is very simple when you replace the complete assembly. 3 bolts on each side.
b) You get a MUCH better fit, because it's a factory piece, not a 3rd party piece.
c) The cost from a dismantler will be less than a new 3rd party plus installation.
Good luck,
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
