My advice:
1) Ask for a print out of the DME, and post your ignitions for the six over rev ranges the DME stores. There should be none in ranges 3-6. There will be some in range #1 and a few, if any, in range #2. Do not buy the car until you see this multipage report.
2) Buy the "S".
3) Here is the CPO language:
"ThePorsche Approved Limited Warranty offers full
peace of mind that in the unlikely event of your Porsche
developing a fault, the affected parts will be replaced or
repaired as required*** with no deductible. The warranty
coverage is limited to the following components:
• Engine: Engine block and all engine internal parts,
cylinder head(s) and valve assembly, oil cooler(s),
head gasket(s), manifolds, flywheel, chains/tensioner,
oil pan, oil pump, exhaust manifold, turbo charger,
clutch master and master and slave cylinders, and
all related engine seals and gaskets if related to
warranty repair.
•Transmission:Transmission case and differential
housing(s) and all their internal parts, clutch master
cylinder, clutch slave cylinder, torque converter, flex
plate, and all seals and gaskets.
•Drive Train: Torque tube, drive shaft assembly,
center bearing assembly, and drive axle with
constant velocity joints.
•Suspension & Steering: Steering wheel, rack and
pinion steering gear, power steering pump.
•Cooling System: Water pump, fan, thermostat,
radiator thermoswitch, and all related seals
and gaskets.
•Heating/Air Conditioning: Heater/air conditioning
regulation controls, a/c clutch, compressor,
condenser, evaporator, control unit for climate control.
•Fuel System: Fuel injectors, throttle valve housing,
air flow sensor, intake air distributor, intake manifold,
pressure regulator, temperature sensors, control
units, warm-up regulator, fuel distributor, fuel line,
air pump, and all related seals and gaskets.
•Electrical System: Fuel pump, oil temperature
sending unit, turbo charger water pump, alternator,
voltage regulator, starter, radiator fan switch,
ignition coil, ignition distributor, hall sensor, knock
sensor, distributor cap(s), rotor, ignition cables/
connectors, high beam switch, all electrical motors,
pumps, and all control units for the following factory
installed systems (if
equipped): Anti-Lock
Braking System,
supplemental restraint,
wiper/washer, intensive
headlight washer,
headlights, door lock, power
windows, rear wiper, rear
hatch release, spoiler,
cruise control, factory
alarm, Porsche Dynamic
all-wheel drive (Carrera 4),
limited slip differential (928),
tire pressure warning (928),
central information panel,
on-board computer, and
climate control.
•ABS Brake System
(if equipped): ABS wheel
sensors, control unit,
modulator, ABS
hydraulic pump.
•Supplemental Restraint
System (if equipped):
Air Bag control unit and
airbag sensor.
•Brake System: Master
cylinder, brake pressure
regulator, brake pressure
accumulator, brake booster.
Limitations.
The warranty does not cover:
•Batteries damaged
from storage
•Batteries damaged from
lack of use
•Tires damaged by
road hazard
•Tires damaged by
premature wear
•Parts that fail due to lack
of maintenance
• Normal wear and tear
• Cleaning and polishing
• Lubricants
•Air conditioner
refrigerant charge
•Glass Breakage
•Vehicles originating outside
of USA and Canada
•Unauthorized modifications
•Wheel balancing and tires
Validity.
For added convenience, your
Warranty coverage is included
in the purchase price. Since
the warranty applies to the
vehicle rather than the owner,
it remains intact and can be
transferred with the private
selling of your Porsche.
Porsche Roadside Assistance.
Your Porsche Approved vehicle
also comes with Porsche Roadside
Assistance, an exclusive support
service that offers added security
when travelling at home or abroad.
In addition to breakdown, accident,
transport and recovery, the
program includes a range of other
coverage services. Please see
your dealer for more information.
Peace of mind.
With the added security that
comes with comprehensive
warranty cover, you can now
look forwardto many thousands
of miles of even greater driving
pleasure from your Porsche.
*** Warranty Coverage: Porsche Cars North
America will repair or replace with a new part
distributed by Porsche Cars North America,
at its sole option, any factory-installed part
that is faulty in material or workmanship under
normal use. Warranty repairs will be made
free of charge for parts and labor at an
authorized Porsche dealer. "
