Old 10-31-2009, 07:37 PM   #13
Banana S
Fabspeed bypass pipes arrived today...
I ordered a set of Fabspeed secondary cat bypass pipes this week and received them today. My observations, in no particular order:
- The pipes are VERY nice quality. Very impressive, although for the price I suppose they should be.
- No instructions came with the pipes, which doesn't really bother me, but some people might find that disconcerting.
- Porsche's choice in hardware sucks. Just sucks. Sucks hard. Really. There are ten (10) bolts holding the stock cat bypass pipes to the muffler and the headers. Seven (7) of the ten (10) bolts broke immediately upon trying to remove them. (And I sprayed all of them with WD-40 first.) One (1) nut was so rusted that I could not get the socket on it firmly, and I ended up rounding the edges of the nut. Had to use a Sawzall to remove that nut. The remaining two (2) nuts, which happened to be the two (2) nuts that are hardest to reach (at the top of the flange connecting the secondary cats to the headers), were TACK-WELDED to the headers! Yep, some genius attached the secondary cats to the headers, then once the nuts were tight, he tack-welded the nuts to the headers. Brilliant. I was able to remove one of those two nuts with a combination of a Dremel tool, a Sawzall, and a die grinder. I'm going to finish removing the last nut tomorrow, after I buy another Dremel tool. (In fairness, this one was on its last legs anyway.)
- Because the four (4) bolts closest to the muffler broke (or had to be cut off with a Sawzall) when I tried to remove them, I'll need to pick up four new nuts & bolts at the hardware store tomorrow while I'm picking up that new Dremel. To those planning to do this install yourselves, I'd recommend picking up those four bolts beforehand.
- It's been said plenty before, but it bears repeating: The Fabspeed secondary cat bypass pipes are MUCH lighter than the stock secondary cats.
Can't wait to finish the job tomorrow and see how it drives & sounds.
Banana S is online now   Reply With Quote
