Old 10-27-2009, 07:22 PM   #18
demick
I guess I don't understand your graphs or explanations.
You say that the first graph is a comparison of before/after techo-torque install with no other changes.
Then, the 2nd graph is before/after an ECU reset (disconnect battery).
But, the hp vs rpm curves of first and second graphs are absolutely identical, which indicates that the two graphs are showing the same set of runs.
So something seems wrong - either in the graphs that were posted, or in your explanation of those graphs.
Demick
'04 Boxster S
demick is offline   Reply With Quote
