If you have a dremel tool or access to one use the buffing wheel with some sort of buffing compound and that thing will shine like no other(for the tips). The buffing wheels are much more gentle than steel wool so you could maybe do the same to the wheel lip as well. Since the tips are stainless steel I believe I would try to get a polishing compound suited specifically for steel for the best results.
