Old 10-23-2009, 09:32 PM   #10
geoff
As you have a 2.7, you should also consider going to the "S" oil cooler if you have not done so already. At more than twice the size of the base heat exhanger, it is a great upgrade for $200.................
Charles or Jake - is the larger "S" oil cooler on a 2.7 a good idea or not? I've read conflicting stories about it keeping the oil cooler as well as causing the coolant to run hotter. With everything else you guys have talked about to date, I don't remember seeing this discussed before, but it sounds like this is a straightforward replacement for the stock 2.7 oil cooler. Do you guys use these on upgraded 2.7 engines?
geoff is offline   Reply With Quote
