Originally Posted by Adam
Clubehead, I know you have an 02....but do you think one pair of the factory cats is eliminated with the Dansk header/cat combo on 03/04's. If so, I think I may have to relocate one set of sensors. I did some reading on header swaps at work and it looks like it only takes an hour or so to do the job as well.....I was pleased to see that. I'm not sure about the install time on the cats though.
Yes, the Dansk headers will no longer have any cats on them so you get rid of the cats on the stock headers.
The header swap is pretty straight forward PROVIDED you've a manual which I know you do
If it's a tip like mine, the right cat will touch the tip gearbox and some bending & grinding will need to be done
For cats, if you've all the proper clamps, I think it'll take about an hour?
