Old 10-19-2009, 07:59 PM   #10
trieullionaire
Underside of door handle
Hi I've received quite a few emails on how the ledz were mounted under the door. It is mounted on the flat underside of the door handle, lights shining down. I drilled a very small hole enough for the wire to poke through.
I drilled up instead of the side, as I felt it was the better choice against rain and all...although, the hole really is too small especially with the wires fed through to really be any issue at all.
Anyhow, here are a couple pics to see the underside and also what I did with the door panels removed.
trieullionaire is offline   Reply With Quote
