Thread: sigh.. CEL
Old 10-17-2009, 11:22 AM   #1
Bladecutter
Originally Posted by stateofidleness
ONLY 53k miles!! WTF! i lose faith in Porsche's dependability a little bit more every day... when they're working, they're a blast, when they're not, it's the biggest pain in the ass.. and it seems like way more frequent than on other cars.. what gives??
Its time for you to step away from the car and take a couple nice, deep relaxing breaths. You are getting wound up too much about the car.
Yes, it is possible that it is the MAF sensor causing the issue, BUT you would be better off if you first started by cleaning the throttle body, since you had an AOS failure, there is bound to be lots of carbon build up on it.
I am sure that once you clean the throttle body, your hunting will be reduced, if not eliminated. If you want, you can even buy some MAF cleaner, and spray it down, too.
I have a '98 with nearly 89k miles on it, which I bought back in February, and I've put on 10k of those miles myself. I just had to replace the MAF yesterday on my car, because it went bad, and set off the P0102 code, and I checked its functionality with my Durametrics program, and saw that it was out of spec. That cost me $180 to replace, but its the first actual problem the car has had in the 10k miles I've put on the car.
I'm just glad I bought the Durametrics tool back in the summer so that when I needed it, there it was. If you don't have that, you might want to invest in it, if you are mechanically inclined, that is.
BC.
Its not how fast you go, or how expensive your toys are.
Its all about how big your smile is at the end of the day that truly matters.
'98 Silver Boxster, '08 Ducati 848, '89 Honda Hawk GT, '89 Honda Pacific Coast
Bladecutter is offline   Reply With Quote
