When you push the shifter side to side it rotates inside white nylon plastic bushings and plastic inserts; one in front and behind the lever. My guess is you have binding in there preventing the shifter centering. You can't pull it apart easily without breaking the bushings, so it might be a good time to upgrade to an aftermarket unit or maybe a 987 5 speed shifter.
