Old 10-15-2009, 04:29 PM   #13
Frodo
Just don't do what I did the first time. I got, I'm pretty sure, the exact same drain pan that mptoledo linked. It's got one hole in the center to catch and drain the old oil. When removing the drain plug (which was still hot), I managed to drop it and, of course, it went into that one and only hole.
Ended up with a pool of used motor oil roughly 6' in diameter on the driveway. It was a terrifically fun clean-up, sarcasm intended. Afterwards, got my electric drill and put on the biggest bit I had (1/2") and drilled about 8 holes in the top, around the center hole. Predictably, I've never dropped the plug into the center hole since.
I still (and would recommend to others) put down newspaper below and around the catch pan. When the oil comes out, it often hits the top of the pan (the part I drilled the holes in) and sends out this wave of used motor oil beyond the outer perimeter of the drain pan. Last time I didn't get a drop on the driveway, though I make no guarantees I'll always be able to achieve that.
