Old 10-15-2009, 05:29 AM   #4
JFP in PA
Originally Posted by billy@EUPHORIAworld
03 boxster 2.7
I had a fender bender up front damaging a radiator and ac condenser so I need some good suggestions or just to go with oem fluids and also how do u recharge the refrigerant
The OEM coolant is readily available and about $24/gal. Mix it with distilled water only, and you will be fine for many years to come.
The A/C system requires the leak/damage be repaired, then evacuated with a pump before refilling with the correct amount of coolant and lubricant. This is definitely a job for a properly equipped shop………
