Originally Posted by scottmcdaniel
* I received only one key with my car - it has no buttons for any sort of remote activities. The car itself has the sensors indicated in the manual as part of the alarm/unlock system - how do I determine for sure that my system has an alarm? Is there something I can look for before I go to a dealership and look dumb in person?
sounds like you were only given the valet key. contact the seller and request the actual key. once you lock the car you should see a red light on top of the dash and in the front of the radio blinking. this tells you the alarm is active.
* I only have front speakers - what I've read indicates I likely have wiring in the back for the add-on set, and that there may or may not be holes cut out in the door - but my panels don't have any grills - is there a way to determine this without popping the panels off (I dont want to break anything)? If so, is it safe to assume that there are wires in there waiting to be hooked up to speakers?
i believe you would need to run the wires yourself, but they're usually sent with the speaker kit. i know my box has the panel speakers but no rear speakers. the "holes" for the rear speakers are behind the seats in the compartment area under the loops / wind screens. here's a link to pelican's site on how to install the speakers.
http://www.pelicanparts.com/techarticles/box_rear_speakers/box_rear_speakers.htm
* Is it possible to replace my plastic window with a glass one short of buying an all new top? Should I bother ( I live in Georgia - mostly warm year round so no frost or snow - also garaged)?
not sure on this one, but i believe the way the top folds for the plastic vs glass would mean it would not fold down correctly. someone correct me on this if i'm wrong. the tops from GAHH seem to be very well regarded and the cost isn't too bad - $1200-1500 for the top and installation labor. if there's nothing wrong with your plastic my opinion would be to wait until it breaks / tears and replace it then.
* If I wanted to change the lights (to blue) behind the speedometer cluster, are they bulbs or are they the soldering kind? Do you have recommendations for doing so?
it's possible, but you'll have to disassemble the entire cluster, which just means once you put it back together something won't work right. the lights are soldered on.
