Chances are if your side window glass is wobbly or doesn't go up and down right or goes up at the front but not the back part or vise versa....
Your window regulator needs replacing.
You access it from the inside by taking the door panel off.
It takes a mechanic about 90 minutes to do it. I guess you could do it too with instructions you can find on the internet and buying the part from a dealer.
