Originally Posted by aussieboxy
Hi all,
I'm looking to put some headers on my MY00 2.7 and wanted to get some advice on weather it is worthwhile to change the remainder of the exhaust.
Where do the performance increase lie, in the headers alone ie is the standard Boxster Muffler System efficient.
I'm not concerned about the exhaust note....more interested in performance.
Cheers
A well designed after-market muffler will most certainly give you better sound, and, perhaps, a bit more hp. However, combined with a set of well engineered headers that incorporate longer, equal length primaries that flow into a true merge collector, together with higher quality, low cell catalytic converters will certainly result in an increase in power. Keep in mind, this application involves a delicate balance, wherein only products with excellent workmanship and designed can be utilized in order to avoid CEL's and maintain proper back pressure.
