I would check your charging system.
Check the voltage across the battery terminals with the car running. I had a motorcycle that was going through headlights one after the other, and it turned out that the charging system had stopped regulating, and while riding, it was running at about 20V, which was causing the bulbs to draw nearly 2x the power they were designed for, which was causing then to fail.
2003 Boxster S
1995 Ferrari F355 Spider
San Francisco, CA
