Old 10-07-2009, 06:00 PM   #20
Perfectlap
Perfectlap's Avatar
Originally Posted by AUDIOGUY
Alright, Perfectlap, tell me more about No-Rinse...
I gather that I dont pre-wet the car. I get my solution of No-Rinse and water, dip a microfiber towel in it and wipe down the car. I then just dry it with another Microfiber towel and I am done????
Seems too simple.
Is this accurate?
as Timoty said yes its that simple. I mean think about it. How dirty does an ethusiast car really ever get? If you've got enough wax on the car the dirt should just slide off with the wet sponge (prefer a sponge or sheepskin to MF towel, no pricky ends).
However its not a bad idea to hold the sponge over the panel so that the water trickles down onto the surface. That will lossen the dirt and cut down on the friction. I might do this to all the panels and then go back and wipe down the first panels in that order. Friction is your enemy when washing and drying.
When you wipe the car do it in the direction of the wind. Don't do the back and forth rub. After each pass dunk the sponge and give it a wring. the soil in the water falls to the bottom of the bucket.
When it comes time to dry use a waffle weave towel (no prickly ends). Spraying a quick detalier while the surface is wet is a good idea to lubricate the drying. You get the shine from buffing out the detail spray as a bonus. I don't do this because FK1 425 spray doesn't mix well with wet surfaces. I have to dry the car first and then treat it with 425. You should dry much the same as you wash, one long pass to minimize the amount of contact with the cloth and paint.
For the wheels you just have to use a little more elbow grease if you're using No Rinse and a wheel brush. But if you have five spokes you can wax the wheels and treat with 425. That keeps the brake dust from sticking. The dust usually slides off with one pass. I dont' know about mesh wheels, those are a pain.
If you search YouTube you'll see a bunch of people on there cleaning even Ferraris with NoRinse
p.s.
Woolite in 1 to 3 parts water mix to clean the carpeting. No need to spend money on something else. Just a terry cloth towel or microfiber.
BORN: March 2000 - FINLAND
