Old 10-07-2009, 07:29 AM   #2
Noboarders
Sorry I havent tested anything yet. However, I found the invoice when I had the daytime running lights installed.
It states:
A customer states have day time running lights installed
S16 Wire vehicle for daytime running lights
1) 838 CPP 3.00 (labor)
2) 1 61-36-1-729-004 Relay
3) 1 PNA-721-043-00-036 repair set F - #9600
Parts: 44.63 Labor: 300.00
35265 wire vehicle for option M606. Fuse A6 install for 30 Power
Terminal 85 & 86 pre wire to vehicle 15 power circuit. Terminal 87 via
Relay operate option M606 – Relay install in relay support #1 relay
Location #1
I tried to remove the relay but they installed it to tight to the wires. I will try the trouble shoot this weekend.
The first item is hours of labor, the second item is the relay but what is the next item "PNA-721-043-00-036 repair set F - #9600"?????
Thanks again for all the help
Noboarders is offline   Reply With Quote
