Old 10-06-2009, 08:25 PM   #14
pk2
Originally Posted by blue2000s
Adding a forced induction system to a high compression engine will certainly require an increase in octane rating in the fuel you use for safety. Compression pressure is higher, ...You would want the increase in octane to resist the chances.
All very true. Pistons can come to look like Swiss cheese fondue on a connecting rod to.
Actually, it's popular within the tuners of turbo engines to use E85 (speaking of E85) because it's octane rating is very high, which allows for high boost levels beyond what you can do on pump gas.
So what you seem to be saying is rating (burn starter energy), by whatever means (ethanol, whatever), is more important and the actual energy content doesn't matter much with a blower. In fact, the rational for the 91 oct. sects belief system is opposite to that which you are suggesting for this app.
Interesting about e-gas. I've not seen it...but I haven't looked either. What is it likely to dissolve?
Regards, PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
