Thread: No headlights!
Old 10-06-2009, 06:41 AM   #2
mikefocke
Check the obvious first
Swap bulbs around in the headlights, fogs to low beams (upper bulb).
Once that rules out simultaneous burnout, move to fuses.
A9 and A10 are the right and left low beam. Under the dash. Switch with A1 and A2...all 15w fuses. That switches the low and high beam fuses.
We will assume you have done no recent wiring, that you haven't replaced the ignition switch recently. And that both are working correctly. And that everything else in the car is working.
