Originally Posted by Jaak
The 02's seems to be controlled the same. The T is attached to the "butterfly" unit with a few longer bolts. Thought someone here may have some experiance on this.
I had thought that up to 03, the intake "T" plumbing are the same and that after 987 series the intake "T" has the internal baffling/routing just behind the throttle body and the controlled butterfly at the "T". this is not the same as the throttle body butterfly.
picture shows the baffling/routing along with butterfly at the junction
