Old 10-04-2009, 02:34 PM   #1
mptoledo
Truthfully, I paid the $50 to let the BB guy do mine. They are insured and if they screw something up they have deep enough pockets to fix it. I also bought a JVC HD50?? something. It wasn't the easiest install as he had to use a second wiring harness. He commented that the fronts and doors shared a common ground. the rears were not hooked to the amp but to the Headunit and now they blow the amp speakers away. I have to adjust the fade to 2 or 3 (front) to get the sound evened out.
Originally Posted by gschotland
I'm in the process of trying to replace my dead CR-220 with a JVC CD head unit. My '02 S has the Bose system with dash/door speakers and the front trunk-mounted amp. The plan is to keep the amp and replace the speakers shortly after the head unit.
The JVC & model 70-1787 harness were purchased from Crutchfield. I carefully wired everything up and the speakers didn't work. After some research online, I quickly came to the conclusion that I need a 70-1784 harness to get the proper speaker connections.
The JVC has both speaker level outputs and 2 pairs of RCA line level outs. Which ones should I be wiring up to my adapter harness? I can't tell whether the old Becker's outs were speaker or line level. I thought most amps like line level.
Thanks,
Gary
I'll take my Guns, Religion, and Money; You can keep the "CHANGE" B.O.!!
SO, GROW A PAIR NANCY AND DRIVE IT LIKE YOU STOLE IT!!
http://i826.photobucket.com/albums/z...Main/MyBox.jpg
mptoledo is offline   Reply With Quote
