			Good flow chart with diagram Mike.
 Probably not MAF related.  If the problem occurred soon after a little invasive washing you may have gotten the pump or a relay wet and toasted  a fuse.  Real easy fix.  Also check for loose or damaged wiring to the air injection pump.  The "signal implausible" term is a weak German/English translation for "open circuit" or "no signal" from the sensor.
 Good luck with your fix.  Definitely not the end of the world.
				__________________2009 Cayman 2.9L PDK (with a few tweaks)
