Originally Posted by Bob O
Johnny, Can you tell us what year Boxster and what length belt you used? Did you get it from the dealer? Needing a shorter belt is my concern too and I'd like to have all the "goods" on hand when I do the change.
Bob
Bob,
It is my understanding that both the 986 and the 987 boxster all use the same size belt. With that said, after calculating the difference in circumference size between the two pulleys, the conclusion was that a belt which was 31 mm shorter than the stock one was the ideal choice. Therefore, the Gates #k060820 was determined to be the best choice.
Johnny
