Thanks for the response.
Without removing the bulbs, I removed the high beam electrical plug from the high beam bulb and installed it in the low beam bulb.
All bulbs are ok. I tried using new bulbs and still same results. High beams and fogs are working. Seems like no no power from low beam plugs.
Keep in mind that no low beams on both Rh and Lh side.
Its raining today and maybe the electrical component that the dealer installed got wet. no oppurtunity to go back to the dealer. Warranty is done and its located in Florida and Im in Canada.
Where would the dealer install this component?
