Originally Posted by Maxodus
I'm sure it's been noted before but just to re-iterate - you may have a special Porsche drain plug that requires the Porsche special socket to unlock it. Some people (including myself) would simply use a screw extractor to remove it and then replace it with a hex head drain plug. Don't let that catch you by surprise~
Actually the drain plug came off easily with a big allen wrench. I cant remeber which one, but it didn't take much to move it. Just beware that if the oil is hot, which it should be (so the gunk stays in the oil and doesn't settle), it will come out extremely fast!! Use a walmart or autozone $8 / 10 quart drain pan. It will fit under the car when you lower the jack. It takes about 20 minutes for the oil to drain.
