MOM is the best anti-seize that I have ever experienced.. It doesn't effect spark plug grounding while protecting the plug from seizure.
I learned this trick as a Marine working with Gas Turbine engines.. MOM is the only thing we were allowed to use on the ignitor plugs that screwed into a 55,000 buck combustor.
Nothing on your M96 gets as hot as the coolest portion of a gas turbine combustor... We actually had directives that called for MOM.
I have also used tooth paste, dental floss, playdough and Ajax/ Comet in the creation of engines over time :-)
