Here in San Diego, winter is when we find out if the convertible tops still go up.
Suggestion: Those of you using jack stands - why not take most of the weight off each corner without actually lifting the tire off the floor? That way you're removing _most_ of the weight, but you're not dangling the suspension from the struts, which at least some of the folks here suggest is a bad idea.
