Old 09-21-2009, 11:07 PM   #2
Lil bastard
Lil bastard's Avatar
If I had to guess, I'd say your MAF is on the way out. The intake temp sensor is integral to the MAF.
As far as running hot, there has been much discussion about this. Before deciding you need a fix, first be sure that the rads are clean - they are notorious for picking up all sort of debris from leaves to candy wrappers, cig butts and even birds.
Also be sure both your fans are operating. If not, check connections, fuses, relays and finally the series resistor in the fan wiring harness - this is replaceable as a splice-in part.
If all this checks out, consider a coolant change and be sure it's properly bled. Also consider the low-temp t-stat. Use the search function to see all the discussion surrounding this.
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
