Old 09-20-2009, 08:32 AM   #20
jaykay
jaykay's Avatar
LWFW to prevent RMS/engine damage
Just curious as to whether anybody knows whether a light fly wheel could mitigate crankshaft and RMS damage by reducing the overhung weight at the back of the crankshaft. I would think the DMFW at 40 lbs, slightly unbalanced, on a slightly untrue crank could cause undue crank shaft deflection resulting in RMS damage and leaks. I would think by the time you have an RMS leak you already have engine damage.
I was thinking of a LWFW just to prevent this scenario but I am just learning about all the negatives associated with it. I have a very low mileage engine (m96) that I would like to make reliable.
What flywheel would I use to be safe? Do I need a clutch to go along with it? It is not a race car so I would like to keep it as streetable as possible. What are the risks? Will a dynamic balance problem be caused?
Thanks,
jaykay
