Old 09-18-2009, 12:19 PM   #13
Franco
Franco's Avatar
Hi Mightysquirrel,
Could this be the culprit for the pedal effort ?
The pivot point and the release arm should be inspected for wear,
especially the arm at the point where it moves the release bearing.
If the arm has worn at
the engagement point, it will require more pedal effort to disengage the clutch. There is
usually a slight curvature on the arm at this point. Inspect to ensure that it is still present.
If excessive wear on the arm is present, replace the arm.
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
2015 Chevrolet Corvette Stingray manual
Franco is offline   Reply With Quote
