Old 09-17-2009, 04:53 PM   #15
onshore
Guest
Posts: n/a
AC Filter
Originally Posted by texomawaves
I'm a newbie here... bought my first Porsche (98 Boxster) one week ago. Yes I'm very excited and wow, do I have a lot to learn. I've had the oil, tires, brakes, etc etc maintenanced. But Damn... where is the air filter? I'm an experienced shade tree mechanic and this car has me starting from basic 101 Thanks! Chris
While you're changing filters check out your AC filter in the front of the car by the battery. I can almost guarantee you it has not been changed either. Once you remove the cover that shrouds the battery you should see it and there is a drain there that collects leaves and debris you will want to clear it as it can cause you grief if it's plugged and the compartment fills with water.
