Old 09-17-2009, 07:26 AM   #2
JAAY
JAAY's Avatar
Under the fron trunk--Nope, In the rear trunk--Nope, Under the engine cover, under the compartment, under the carpet, in the airbox on the drivers side--YUP! Two little tabs on the sides of the air box that bend out and the you slip/pull the air filter housing up and there you have it. I recommend a BMC drop in filter. Good Luck and welcome.
JAAY is offline   Reply With Quote
