Thread: IMS Retrofit
Old 09-16-2009, 06:24 PM   #12
Jake Raby
Engine Surgeon
Single and dual row fail at a rate that can't be calculated. If its a factory bearings, it is at risk of failing.
What year is your car??
the only way to REALLY know is to pull the bearing flange and visually inspect the bearing... .. We have a list of serial numbers and etc that dictates the engines that have each bearing, but it is not accurate. Nothing is accurate except a visual inspection.
