Old 09-15-2009, 11:45 AM   #10
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by Jake Raby
This is the same part that is factory in a 2008 997 engine making more power than the modified engine I created, but without the throttle response.
I am building a 3.8 X51 engine right now, this is the same component that was factory equipment in that engine as well. They are the same length and weigh exactly the same.
Needless to say, I won't be completing another engine until the new component is completed as everything I have in my line up now has the same or even more performance than the engine that suffered this failure.
If that's the case, then I stand corrected, and you've dialed in too much throttle response!
