Old 09-15-2009, 06:58 AM   #9
Franco
Franco's Avatar
Hi, I had a similar problem, try tapping on the cluster assembly, sometimes it's a loose bulb or connection. If that doesn't work remove the cluster and replace the bulb.
Did you do your homework and verify the mileage on the car wasn't altered, the reason I ask is because the cluster is removed to change the mileage and sometimes reconnecting the plugs can cause a problem.
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
2015 Chevrolet Corvette Stingray manual
Franco is offline   Reply With Quote
