Thread: Is this bad?
Old 09-14-2009, 07:50 AM   #10
onshore
Guest
Posts: n/a
Originally Posted by 2K3_Boxster_S
I have to agree with you. Even on closed race course you are taking a risk, but that risk is Greatly reduced by the fact that it is being done in a controlled environment. Therefore making it a bit safer. It really is dumb to go flying 133mph down a public road regardless of the time of day or congestion. Not to say that I havn't done it. I have turned towards AutoX and Closed Circuit Courses for pushing the Boxster past legal freeway speed zones.
Also, back to your comment "I've tried, unsuccessfully, to break the rear end loose by going 65 ............"
I am assuming you have PSM turned on when you tried this? It is fairly easy to get the back out with PSM turned off. I would not suggest trying at speed of 65 mph. I keep it off for lower speed autocross.
My Box doesn't have PSM so I've been attributing it's traction to the PZero tires that are on it. The turn I mentioned also has a very wide hard packed dirt ramp next to where the car would slide into and not impact anything if it did break loose. I'm going to the SR Autocross this Saturday for the first time and expect it to be challenging enough to give the car, and more importantly myself, a test. I want to come away with a better idea of how to drive this great piece of machinery.
