Originally Posted by ChefCarnivore
Are the crush rings available at someplace other than a Porsche dealer? Where? How do I specify it if the only one is the one on the car?
What are you using to drain the oil in? I will have to jack the car up to remove the drain plug then level it to the ground with a clearance of 4".
Here's a little how-to I made on oil changing:
http://columbiaporsche.freeforums.org/986-oil-change-t16.html
I used Rhino Ramps to lift the car. Very easy and stable.
You can get a drain plug online at somewhere like pelicanparts.com, or try a local AutoZone or other auto parts store for a similar washer. Do you have two cars or another way to get to the store? If so, drain your oil and take the old washer with you.
