Originally Posted by ChefCarnivore
Are the crush rings available at someplace other than a Porsche dealer? Where? How do I specify it if the only one is the one on the car?
What are you using to drain the oil in? I will have to jack the car up to remove the drain plug then level it to the ground with a clearance of 4".
Hi, Google Oil Drain Container and for the washer put back the same one after you measured it and then take all the time in the world to buy another.
When you jack the car DO NOT GO UNDERNEATH WITHOUT JACK STANDS
