Old 09-11-2009, 01:24 PM   #2
JFP in PA
Originally Posted by 23109VC
i've got a leaky water pump.... i have the same symptom as you in that it only leaks after I shut off the car. i believe since once the car is running, it heats up, coolant expands, and it's all under pressure... so when you get home and shut off you are leaking.
You have a water pump that is leaking by the right front wheel? I'd really like to see how that works.....................
