Old 09-11-2009, 12:18 PM   #4
23109VC
i've got a leaky water pump.... i have the same symptom as you in that it only leaks after I shut off the car. i believe since once the car is running, it heats up, coolant expands, and it's all under pressure... so when you get home and shut off you are leaking
i'd get it fixed. my car is not being driven now until I get mine to get fixed. I'd HATE to have it finally blow, dump all your coolant, and ovreheat before you coudl get it shut of. given how $$$ it is to repalce an engine, I'd hate to neglect a fix like this only to have it cause it to overheat and cuase damage..... some failures just happen and are unavoidable...this is one you can avoid by fixing it now.
good luck.
_____________________________
Cars:
2007 MDX - Wife's mommy mobile
2006 RL - My daily driver
2000 Boxster - Ocean Blue Base 5spd on Black Full leather. 18" wheels and M030.
Boxster mods I've added: Rear speaker kit, Painted Calipers, Painted Bumperettes, Painted Center Console, 987 Shifter Assembly, 3 Spoke Steering Wheel, Clear side markers, 03+ rear lights, de-snorkeled.
23109VC is offline   Reply With Quote
