Alignment questions
I did a search through the achrives for about a half hour but couldn't come up with the info I need so I'm hoping you guys can help. I am considering doing an alignment and it seems using a shop with a hunter machine is a good way to go. I want negative camber up front as it seems right now there is none. Also maybe maybe slight toe out up front. I basically want better handling, grip and response for autocross and track use. What is a good set up and what is the best I can do with the stock suspension?
