Old 09-07-2009, 10:34 AM   #1
chitowndad
there are a few rubber grommets near the steering column that you cut a X with a utility knife and push the cable through. If you crawl up near the pedals you'll see them... Remove the plastic covers next to the batter and you'll also see the grommets from the other side. One of them is behind the battery or just off center of the battery.
Good luck.
2001 Boxster S
Desnorkled
Pioneer Avic D3
JL Audio 6.5 inch subs (in the door)
Pyramid 4 channel amp
chitowndad is offline   Reply With Quote
