			OK  Progress report and important question, many thanks for all responses, it's good to get all opinions and research done before holding wrenches. Mike did get back to me, seems like a very nice and knowledgeable man. Regarding the crank turner, I have the luxury of the factory Fiat tool.
 The bottom line question is this:
 Will hand turning the crank with belts on as slowly as humanly possible and stopping at the least bit of resistance hurt anything?
 The auxillary cam as it turns out has a fuel pump cam on the end of it, the instructions state the cam can be returned to the 1 o'clock position irrespective of the valves and crank, boy is that a "hole tightening" sentence to accept. It was rather ambiguous as it then says it has to be close to the other marks, what? Lil' B has me so jumped up I'll be turning the crank like my EOD cousin takes on an assignment!!
 oh the pressure!
 BTW B, I'm a decent wrench, (smart enough to do homework) but dumb enough not to have found all this before starting the project. My father, still an AFST member mechanic, turned 82 today, he just doesn't remember anymore. He's counting on me!
 PS Steel plugs, Aluminum head, will a break free soak do the job?
 Thank you all.
