Originally Posted by Lil bastard
On an interference engine you do NOT want to rotate the crank if the timing is off. That forces the pistons up into the open valves! If you have that issue for more than a few degrees, you need to remove the head, set the crank to TDC (different for many motors - the FIAT uses the #4 cylinder, NOT the #1), then rotate the cams (off the block) to their approximate positions before reinstalling the head.
How could it possibly be off that much is shut down, not moved and previously in synch? I'm going to email your pal, work net was down all afternoon.
