Originally Posted by rhart
Added input. This car is going to be 98% for track. Hence I may do a removable steering wheel. Does this info change anything? Also where do I get info on the console delete option?
Sorry, it does not change anything. The whole stalk assembly is fitted over the steering column and all the stalks protrude from that axis. If you have a 3-stalk assembly (no OBC stalk), you could rotate that so the CC stalk is out of your way, but like before, all the stalks would then be skewed. With the 4-stalk assembly, rotating it to the left (raising the CC stalk) would lower the OBC stalk, probably just moving your problem to the other side. Using a removable steering wheel won't help, because it is fitted to the end of the column while the column actually fits through the stalk assembly. Now, you do have some fore/aft adjustment available to the stalk assembly and perhaps that would offer some relief. Once you have the wheel off, it will all be very clear.
