Thread: Water Pump
Old 09-01-2009, 07:25 PM   #23
pk2
Originally Posted by jhandy
I will have my car back from Raby soon with, amoung other stuff, a 160 Stat, however lets take this thinking to the extreme.
If lower is better, what would happen if the Tstat was removed and water was allowed to flow unhindered?
Not to hijack, just to understand better.
No problem
I like that attitude. I can see your ratcheting it up bit by bit.
I did take the thermostat out of my old 6cyl bmw cs coupe a long time ago. The problem was it never really warmed up. In fact it was down right cold, in the blue at speed somtimes.
With alot of trial and error, I think 3, 1/8th" holes through the thermostat gave me the temp I wanted (140??...maybe?). To be honest though, I didn't really notice a diff. Only that as db said, it took a little longer to warm up. I guess we're talking 5 hp here? I built the whole engine and tweaked quite a bit. 5 hp just might not have registered.
But, I think I agree with db, It's used to be, and I pretty sure it's still true to a degree, only when the engine was warmed up and running within a certain temp window that all the moving parts have expanded and fit together correctly as designed (we hope). So in a way I think driving around a cold engine is just as hard on it as driving it to hot.
Anyway, pop in any time. I'm the hijacker here. Till I arrived this thread was about changing a water pump. PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
